VTPete
- Jan 26, 2020
- Lakeside, CA
- Ventana LE
- Ford F150 King Ranch
Thanks I’m going to pull over and check oil level again. My tandem outside tires are alarming saying 84 pressure. This is starting out to be a heck of a trip.
Oil level checked and fine. Temp now done to around 213F. Tires were down a little now aired up but still registering 82 and 84. Alarm will still probably go off. Sensor is not picking up the change.OK Cummins ISX then. I checked online and it seems up to 230 or so is pretty normal. Maybe someone who actually owns one can confirm.
What is ISX and how did you know I have that?OK Cummins ISX then. I checked online and it seems up to 230 or so is pretty normal. Maybe someone who actually owns one can confirm.
Thank you. I will try and remember that. Had a rough day. Now at a rest stop for the night with a cocktail. Had someone clear our engine light. Error code was sensor on turbo. Tires alarm still going off every 20 miles between t pressure fine. IDK!!I checked and 2014 King Aire had the 600HP ISX Cummins engine
I am wondering if your high pressure alarm is set way too low. What is your cold air pressure in your tires supposed to be? The high pressure alarm should be set around 25% higher. Low pressure and tire temperature is typically the more worrisome factor. If a leak causes your pressure to drop, you get more flexure of the sidewall and greatly increasing temperatures and then are prime for rapid tire failure.Oil level checked and fine. Temp now done to around 213F. Tires were down a little now aired up but still registering 82 and 84. Alarm will still probably go off. Sensor is not picking up the change.
