Need some help
Delamination is a result of poor glue up or water infiltration or both. Many people never look at their roofs and seams, so poor maintenance is responsible for some of it. Tree limbs can poke a small hole without being noticed and it takes no time from there. As to electrical issues, the answer is that there is no code enforcement in the RV industry. The fixtures are the cheapest and lightest possible. They are not installed by electricians. The outlets they use are horrible. They push the wires down into metal slots like the crappy little things you buy to splice into a wire without cutting it. Prone to loosen with vibration. In the newer units people come into the forums all the time with pictures of a rats nest of wires in behind the panels. Just yesterday I worked on a 2022 model 5th wheel that had 9 different issues to deal with. Many people are getting an inspection of the unit by certified inspectors. This is pricey but they have a comprehensive list of things to test for you before you purchase. Better to find out before you buy then on your first trip.
A lot of good points. Being a retired contractor I planned on spending time on the roof on every trip and when stored without a cover. Changing recep and fixtures isn't a problem as long as the wiring behind and above is correct. Hate to have to reno when something is new but let's face it how many times do u get something and have to become the engineer to correct problems. Thanks for re-enforcing the Full inspection point. Structural, electrical, plumbing and minor engine checks are fine but I don't really know the other systems associated with a Motorcoach. Thanks for sharing your experience with an RV beginner.
I am a former contractor also. Did everything in a house any trades can do over 40 years now. Top to bottom. These things really require people that are handy and a good support network. Good luck to you and never fear asking questions. It is a great and friendly forum.
Thanks for making me feel more at ease after reading about so many problems with RV's. Seems like many headaches can be avoided with basic maintenance and respecting the Coach. Yes, This does seem like a very friendly and supportive forum. I did read that any openings in the roof, A/C etc should be resealed yearly is this so or is it an inspection and common sense situation ?
Air conditioner is sealed with a gasket you can't see, the ac has to be unbolted and lifted up to see it. No need worrying about it unless it starts leaking.
It's a good idea to inspect your roof caulk every year or more often. Around fan vents, plumbing vents, antenna, skylight, etc.
