New member- electric fridge
Not sure what CF your Norcold is, but our fiver is equipped with a large residential frig (no propane). When we are not plugged in it draws 12volt power from two deep cycle batteries. It will easily keep that frig running for 8 or 9 hours on the road or overnight. Before spending a ton of money on different type batteries or additional solar I would try a couple marine deep cycle 12 volt batteries.
I actually put in four deep cycle 6v golf cart batteries. Wired them to provide 12v to the system. Works great, with our 2000 watt inverter.
Thanks Joe,
The fridge model is N10DCSSR
I am currently running off 2 Deka group 24 deep cycle batteries (about 1 year old) which I have load tested to be “good”.
Everything runs fine off solar (3-4 lights on the control panel) until the sun goes down.
Then it drops off overnight and the fridge shuts off below 10.8 volts.
About the only thing I actually know about electrical stuff is that you plug it in to make it work. My only guess is that your Norcold draws a ton more amps then an RV/converted residential frig.
