New to travel trailer living¹
Welcome.
Winterize, if you are storing it. Procedure should be in your manual. Many descriptions online.
I prefer to use the RV anti-freeze in my trailer vs. blowing out the lines with air. Also if you have an ice maker make sure the anti-freeze makes pink ice cubes so you know that's been winterized.
Winterize if not going to use. I blow lines out with pressure tank then add anti-freeze to drain traps. Some will infuse the entire lines. You will find, to each their own.
