Newbie Here from California
Phoebe Redpath
Roadtrek
SS Agile
19'
Sprinter
Hello, all!
Glad to have found this forum! We recently purchased a 2015 SS Agile after owning an '03 Lazy Daze Class C for quite a few years, so we are adjusting to some of the differences between our old and new rig. We have a 2500 Inverter and a propane generator. We have tried to exercise the generator under load by turning on the AC, but the AC is shutting off after running for about 20 - 30 seconds. Does anyone have any advice? Thanks in advance!
I suspect once the compressor kicks in there's insufficient juice to power it, this in itself can be damaging to the AC as I understand it. Determine your power needs then size your inverter/generator or stay within current limits.
Welcome to RVforums from Ely, Iowa. I would have thought if everything was is standard equipment the inverter sizing would be adequate to handle the AC . If it is not original then it could be that the inrush current is too high and the AC will shut down. You can instal a soft start drive in most AC units that will lessen the inrush effects
