Question Newmar under coach heat
Vinny 3547
Hello Newmar folks,
Vinny would like to know how to heat the storage area so our water tank doesn’t freeze?
Thanks much:)
Hello Newmar folks,
Thanks much:)
What is the 3547? Is it a Newaire or other diesl pusher? If so, if your Oasis diesel burner is turned on, and you have the correct zone turned to furnace (in my 4369, I believe it's zone 3), then it will automatically heat the wet bay when it reaches a certain temp, which I think is around 40 or maybe 46 degrees.
As a backup, if I'm in a real cold area, I also have a marine bilge heater in my wet bay, where I had a 110v outlet installed. There are other "backup" options people have used, like work lights, or Davis dryers, which can also heat the bay, but the primary would be your Oasis/furnace.
Hello Tnedator,
Thank you so much for your, really appreciate your response!!!
We have a New Aire 3547 diesel pusher with 2 zones so I’m sure it’s zone 2.
