NewRedOwner
tcisodar
Just purchased 2022 Red 340 38LL. Got it home and now going over/operating everything before first trip. The world not gives the ability to sit outside, tv but doesn’t have connections to connect Grill to RV propane. Anyone know if there is adapter that could give the ability to connect?
You can go on amazon and find the quick connect fittings you need. Obviously you need to change out the fitting to your grill to be able to connect up to RV propane. After owning my motor home for five years I still have not taken the time to set my portable fire place up to connect to my motor home. Still haul around a five pound bottle of propane.
NQN 12FT Male/Female Quick-Connect Low Pressure RV Propane Extension Hose, Compatible with Elbow Adapter for 17"/22" Blackstone Griddles - 1/4" Safety Shutoff Valve and 1/4" Male Full Flow Plug for RV https://www.amazon.com/dp/B092SD4SY7/?tag=rvf01-20
Our MH has a quick connect, all I had to buy was the hose. You will need to add the quick connection to your MH. Should be an fix.
