Nexus Solar Panel feed direct to Battery ?
Spirit72
The new vehicle brief said that the solar panels go thru the battery disconnect switch. The panels will not charge the batteries if the switch is in the off position. Turning everything off during the day to let solar do its job, trickle charging the batteries for nightime boondocking use, seems weird to me.
IF the above is true, how can I wire directly through the controller to go directly to the batteries, bypassing the battery switch ? Wire colors would help in the discussion, please.
Thanks in advance,
Spirit72
2025 23P with two solar panels & two batteries.
