NH Newbies
EFleming65
NH
Coachman Apex Nano
RDS213
Trailer RV
Hello to all. Just joined your group as I find we all have similar challenges regards DYI, towing, programs, cool campgrounds & scenic experiences. The 2018 RDS213 Apex Nano by Coachman is new to us with no manuals, but we have some RV background. Our first challenge is powering everything. Found a single toggle switch in forward storage..still no power, charging battery..looks new 4-2025
I did go to Coach website, but could not find basic "how to operate" info.
All help is appreciated..
Thanks Eric & Tricia
So nothing works on 12V? Did you check the voltage on the battery? You say it 'looks' new' but is there power across the posts? Have you tried hooking it up to shore power (120V) using an adapter and seeing if anything works? Look way under the front of the camper on the right side as you're looking at it and see if there is a red key type rotary switch. If there is that's your battery disconnect and it needs to be turned on to get 12V power to the camper. Another place to check is to see if the breakers are flipped on in the breaker box panel.
What wiscampsin said and look for a 30 or 50 amp fuse under the trailer just aft of the batteries. If the switch is on and the fuse it good check the inverter.
Your convertor is near the fuse panel, probably behind it. On TT's with the battery on the tongue, they run the battery wires thru a 30 amp resettable breaker usually on the bottom of the frame up out of sight. Chase the wires from the battery to find it. Look for a Red switch in the front bay or the water entry area. It might look like a key or just be a round switch. If you are plugged in to shore power the convertor will be powering the camper thru the fuse panel. If you pull the fuse panel out of the wall most likely the convertor will be in there. It needs to be close to the batteries or the panel. In most TT's it is close to the panel. It should be putting out more then 13 volts if you have a meter.
I looked at the floor plan for that model and the only places the panel and convertor could be is under the countertop and fridge and the bunk. Sometimes they us the panel with a convertor built into it, not a stand alone unit. Not usually a switch in a TT. I added one to my battery post in my previous TT.
