No Driver's Side Low Beam
Steve S
Sacramento, CA
Baystar 3124
Ford
V10
2020 Baystar low beam headlight does not Work, just the high beam. Replaced the bulb and no change. Suggestions please?
Do you have a volt meter to see if there are 12 volts to the headlight?
I have found that some bulbs will get hot and will relax the spring tension on metal connectors. I’m not sure what type connector you have, but I found this on my daughters tail light. The type bulb produced too much heat and we changed it to an LED bulb and fixed the connector.
Follow up (please use same thread in the future):
