No Power to Coach or Chassis
HASKONI62
We have a 2020 Coachmen Sportscoach. We store it between trips. Last trip was the first week of December. Went out to start it(we do this every 3-4 weeks when stored) and had no power to the coach or chassis. The batteries, coach and chassis, are 2 years old. Called Coachmen Tech Support. They were as lost as I. Any idea what would cause this? Just looking for a starting point on what to check. I will test the batteries when I go back tomorrow but very doubtful all the batteries died at the same time!
If not plugged in. The battery should be disconnected, either the cable or disconnect switch.
If in cold winter climate, removing the batteries and place in a warm area can help.
We turn off the coach and chassis disconnects. We also turn off the breakers to all the appliances. We are in Charleston SC, so no extended freezing perods.
Wow, it’s definitely a drain beyond the basics. Then it may be more than one thing with coach and chassis being drained.
There are a few techs here, maybe one will answer.
Best of luck on this.
