No power to slide motor
JPJ1
2015 coachmen sportscoach 404RB passenger side slide out ( lippert rack and pinion slide with Klauber RV Slide Out Motor) nothing happens when I hit the in or out switch. My slide was working fine I put it out no problem then the next day nothing when I hit in or out. Checked the motor it was leaking and had a burnt smell. I had a back up changed the motor and still nothing. I exchanged switches from another slide and the switch works fine with the other slide. When the switch is pressed you can hear the relay click. There are 2 relays the same so I switched another slide to that relay and it works. I think its something between the relay and the motor. All the fuses in fuse box check ok. Any fuses between relay and slide motor? there? This is a lippert rack and pinion slide with Klauber RV Slide Out Motor. I check all the fuses in the fuse box any help would be much appreciated.
