Problem No tank readings
Sandman51
23 Air Atlas - No tank readings displayed on Multiplex. Fuse is good in main breaker box. Any help welcomed! Thanks!
12v systems are normally protected by fuses not breakers. You may be looking in the wrong place.
Thanks Kevin. I knew it wasn’t on a breaker. Checked 15 amp fuse in the breaker box and it was ok. Wondering if there’s a fuse underneath before wires connect to tanks. Not very good at this. I do have appointment at the “mothership” in October.
Then I would just put it on the hit list.
