Old one: OBDII connectors?
Old one
Altamonte Springs, Fl
I am planning to buy a 24-28' gas motor home either class A or C. I will hire a professional to inspect it, and be there with him.I do have soem questions--
Most of the motor homes have the Ford V10 and the web sites I visited say they are reliable if it is later than 2003. Do they have an OBDII connector and is it usually under the dash like in Ford trucks/SUVs? (I have the plugin computer and will have it with me.)m
Are the associated transmissions also reliable? I want a comfortable ride as we are pushing 80. We also need reliability for we hate surprises. I am familiar with gas engine ignition systems and computers
My 2016 F53 chassis has the OBD port under the dash by the steering column. I have realistic expectations about the ride quality and although it will ride nice and smooth on a flat surface that is rarely the case. I would not classify it as a comfortable ride.
Just an FYI, Late model Ford F53 (Class A Motor Home Chassis) came with a six speed transmission. A great improvement over the older four speeds.
There's a 5 spd. in between them as well. Mine is the last year for the 5, yours is a couple of years into the 6. They also transitioned from 2 to 3 valve.
OBD2 is a standardized port required by USinc. Starting in the mid 90's. Previous manufacturer standard was OBD1 that is usually accessed by a key sequence. As I recall My 1991 van had OBD1 as did My 1994 dakota
1996 was the year almost everything went to OBDII and the F53's did too. The very first of the 6.8's came in 1997 so by definition all V10's are OBDII.
The earlier V10's had a 5R110 five speed and later ones the 6R140 six speed. Though either is about as reliable as the other I think, the six speed seems a much better match for the V10's power band is you ask me.
As for the engine, they have had some issues but by now about all of them should be long settled by the current/previous owner. One thing to watch out for though is exhaust leaks at the manifold/cylinder head. They tend to break exhaust studs (a LOT of other engines do this too, Dodges, diesels, all sorts) which causes "ticking" like exhaust leaks. It's definitely fixable but probably not something you want to get into right off the bat. On the other hand you can use an estimate of the repair cost as a bargaining chip. These type of leaks tend to be most evident when the engine is "dead cold" and can even disappear completely once it has fully warmed up. So watch out for a seller who warmed up the engine for you before you got there to try and hide this. As for repair, some shops want nothing to do with it and don't deal with them. Other shops have invested in drilling templates, right angle drills, and such to take on that exact work and those are the ones you want to find because they have no problem with the job. If you need such help, you may not.
I was into cars back in 1994 when this came about. You are correct in what you said. The problem with OBDI was the port data string was manufacture written, so you needed THIER reader to access it. Moreover, in that year, Ford had different data strings for: small cars; large cars, small trucks, and H/D trucks. The average mechanics needed 4 of these to service Ford, and the other big 3 were the same. The car owners who lived away from dealers like say my B I L who lives in Freistadt, Mo, had to drive 40 miles to access a dealer, so when the check engine light comes on, and the car is still running, everyone said hell with it. The polution stiuff may have been the fault, and it's polluting. The Gov't stated teh OBDII so the local gas station could afford the reader and do minor repairs or if not send the to the dealer. Also, the common data language allows people like me to diagnose problems and do some repairs myself.
the point of my post is to be able to ":test" a rig on the spot. Minor things that I can fix may not be a deal-breaker.
also good advice. I would try a shop that does trucks that should be equipped.
My four OBDII "car" scanners will all scan F53 chassis RV's just fine. I do not have a "truck" scanner and such trucks in my experience use a completely different "deutsch plug" connector for their scanners. You will find those on rear engine diesel pusher RV's but not Ford gassers. In short, any good OBDII scanner will work. With some you may have to fib a bit and tell the scanner your vehicle is an F550 truck or something. Some cheap code readers don't even know what the vehicle is, they just read and display the codes from the main computer. On a 2006 or newer Ford anything most scanners can figure out what vehicle you are connecting to automatically.
I bought one for my 2003 V10 while out west this winter. Yes it is OBDII
This is excactly what info I am looking for. Thanks...
Welcome to RVforums. I have owned several of the Triton engines and exhaust leak / broken studs have been a problem forever. Still I have found them to be quite reliable overall. Another issue I have experienced iis bad coil packs. Use only Ford as replacements. They are the best out there.
Thanks for all replies. I presently drive a 2003 Expedition, and am very familiar with coils packs. Ford gets $103 each, the Bosch ones are good and $40 each.
Re: exhaust manifold studs... After I buy one, change out all the studs before they rust in?
