Question Option K320
sheridany
Orinda, CA
Has anyone seen or have K320 described on the order sheet as power incline retracting bed as listed on the DSDP order form. Are you able to get to rear bath when slides are in so you don’t have to combat crawl over the bed?
I do not have it (obv. since I have a VTDP), but in any case, I can’t imagine it would. In order for that to be possible, the foot of the bed would need to slide backwards toward the headboard as the top 1/3 of the mattress raised. While completely possible, that would be more expensive to engineer than a simple piano hinge with some actuators underneath that raised and lowered the top 1/3 until it reached at 45-degree angles. Other than the angle of incline, all positions are almost certainly fixed and so the answer is most likely no.
All pure speculation. Hope I’m wrong.
