Passenger side slide out motor
Roadglide117
RVF VIP
North Lima, OH
Ventana 4381
Freightliner
400 Cummins
28' car hauler or 2019 F-150 4x4 Sport
I'm trying to find where the bedroom passenger side slide out motor is located. 2015 Ventana4381. This is the side opposite of the bed frame. Wasn't sure if I pulled drawers out for access. Doing some PM and wanting to check for loose bolts. Thank you!
Under the bed. Lift up the floor panels from the under bed storage.
I found the one under the bed...trying to find the opposite side slideout motor
I'm not sure of your slide configuration. The bedroom slide in mine is under the bed. The kitchen and full wall slides are in the basement just above the basement doors, you can follow the torque rod, whatever it's called.
Thanks Neal...I have 4 slide outs...no FWS..each side kitchen & living room found in basement compartments. It's just the bedroom side with drawers I can't find.
I found the slide out motor for the bedroom side with drawers. It's outside behind tag wheel in a plastic case mounted to frame. There is hole in front facing windshield, that I might be able see in if I raise coach high enough to squeeze in. Seems easier if I take the wheel off.
The "fenders" on most raise up exposing the wheel well, they are hinged. Look at the bottom for self tapping bolts that Newmar uses to hold the fenders in place.
Thanks Neal !...plan to look at that today
I didn't notice that they hinge, but i was able to raise mh high enough to remove screws and plastic covering. At that point easy to get wrench in to tighten bolts
