Porpoising 2019 Cougar Half ton 29 RKS
modom167
I have struggled with this for 7 years and no success. Sorry for the length of this post. Here is what I have: 2012 Ford F 250 Super Duty, 6.7 diesel, 4x 4, regular bed 20" tires and wheels, all stock, Goodyear air bags i use for leveling, 16,000 lb. Curt hitch. Bare truck weighs 9,000 lbs.
2019 Cougar Half Ton 29 RKS, 9,500 lbs. , I have installed the Lippert RotoFlex Trail air pin box to help with chucking.
I have tried bag pressure, full water tank, loading heavy to rest and front, replaced Rancho shocks on truck, changed driving styles, literally everything I can think of top stop proposing and nothing has worked
I'm posting this looking for suggestion. Thanks in advance.
Marko
Welcome to RVforums from Ely, Iowa.
Have you weighed your rig loaded and hooked up to determine where the weight is located? It sounds like a weight and balance issue. Much as when flying you need to situate the weight correctly to balance the load nad performance.
Thanks. No I have not weighed rig complete. I don't carry much gear so not much weight to move. I just thought of something. A little unorthodox. I could fill front Gray tank to add hitch weight.
That's not a lot of weight for your pickup. How are your shocks? Perhaps they need replacing with a more robust shock.
Are all tires filled to a proper psi, both truck and trailer?
shocks are 3 years old Rancho just like originals. Tired on truck at 65 psi. All tires on trailer at 80 psi. I've been reading about this further. Possibility lacking pin weight. Test kitchen model most weight on rear. I'm thinking about filling front Gray tank before towing again. That should add about 240# to hitch weight. What do you think?
Weight distribution.
Properly installed hitch (centered over axel).
Other suggestions are counter productive, so will keep them to myself.
It may be that you are just overreacting to a normal condition, that has no solution.
