Question Propane furnace setting
Pufworks
The propane furnace in our 2023 Chase works fine but does not stop at the set point. Is the sensor in the Firefly panel defective? Or is there an alternate explanation?
While listening to you, I wondered if the burner was out and the fan continues to run. I wondered if you really know what the shut off temperature really is,as five or so degrees above set point is common, for shut off.
The fan continues till the heat exchanger cools. And setting the temperature is not science.
