Tip Properly connecting stranded and solid wires
This is the case in my OASIS hydronic heating system which has suffered multiple shorts. There is a mix of solid and stranded connections.
Interesting. Thanks for posting. I may get those Wego connectors just for the Oasis…
A timely post, I've been pondering a wiring method that allows easy removal for the new water pump install next week. There are two sizes of Wego 221 in the tool box. Perfect to connect the power to the Remco Aquajet.
If there is a failure, the pump can be quickly swapped out for the old pump which will be in the Spares Bin. :-)
Thank you for the post.
Is there plenty of room in the Oasis junction box for the Wagos?
Wago is what I used for the MicroAir install on my 2019 DSDP...I am going to be documenting the install on the 2022 LADP.
