PSA: Check your toad baseplates
Neemer
Crayon Eater
Virginia
DSDP 4326
Freightliner
ISL 450
2023 Winnebago ERA 70A or 2016 Lincoln MKX
My Sprinter-based Winnie toad has one of those two-piece Blue Ox baseplates. This baseplate was installed by my selling dealership, a highly rated and respected one.
Yesterday I discovered that the plate on the driver’s side had a bit of play in it. Not good.
After removing the grill and bumper cover, I was taken aback at what I found. That plate is attached to the frame with a total of eight bolts. Two of the bolts were completely missing, and the other six were in various stages of backing themselves out. Not even a hint of red thread locker on anything. I shudder to think what could have happened if I hadn’t found this.
I took everything apart and put it back together the right way. While the one on the passenger side seemed solid, I disassembled it and gave it the same threadlocker treatment.
While I’m thankful I was able to catch this, I’m super disappointed in the original install job. It wasn’t cheap but was sure cheaply done.
On the positive side, I now know how to remove the front fascia and I didn’t have any parts left over when I put it back together. :)
Going forward, I’m going to do all of my own baseplate installations. This is crazy.
Wow, good catch, I give mine a once over before every trip
PSA: Check your toad baseplates​
And here I was thinking you were talking about your prostate.😊
Did McGeorge install yours? They did mine in 2017 and this happened to me:
We just installed a base plate and found it interesting that the installation manual states that the base plate should be inspected every year for tightness.
We used red thread locker during our install, don’t want to have to remove the bumper cover every year.
I give that a once over every year also😄
The thought of bending down to inspect the baseplate on our FIAT 500 TOAD led me dismiss this option. I'll try and rally my 40 year old son to see if he can locate a loose bolt...otherwise I'll just double check my safety cables.
(Just kidding of course😉) Blessings
It was that Country-Wide Inside place…Vegas branch.
While Loctite red thread locker is good please check to see what the recommended torque on he bolts are use thread locker as torquing to proper torque. Travel Safe
