Question re: converter wiring
MikeinWisconsin
I am installing a Progressive Dynamics PD4045 to replace the 25 year old Centurion CS3000 in my 1999 Jayco popup, and I have a question. The AC side of things is working, all of the outlets are as they should be, but I can't get the 12VDC to work. Since there are no installation instructions as far as how to use the black wires coming from the back of the converter, I assumed that the black wire coming out of the back of the converter should be connected to the black wire from a 12VDC light, for example, and that the white wire from the light should be connected to the frame ground, which is in turn connected to the ground busbar in the converter (for shore power and the converter ground wire). What did I do wrong? I measure no DC voltage from the black wire coming out or the converter to either the ground busbar in the converter, or the neutral busbar (white wires for shore power and converter) in the converter. The fuses check out OK. I went through the troubleshooting guide available online from PD for this converter, and everything checks out, indicating that the converter itself is not defective. I'm at a loss, if anyone can help.
(Note: I do not have a battery hooked up).
