R1T and Pebble Flow - First Journey
We picked up our new Pebble Flow Founders Edition at Pebble HQ in Fremont CA on 11/19/25 and began our indirect journey home to Durango CO. We’re towing with our R1T, dual motor, performance, max pack on 21” Michelin Defender LTX M/S2 tires. This same truck towed our 28’ Airstream for over 14K miles. The single axle Pebble is 24’ 8” LOA, 7’6” width, 6800 lbs GVWR and is equipped with dual electic motors and a 45kWh LFP battery pack. All utilities are electric - no propane. It rolls on 275/70R18 Goodyear Wrangler Workhorse All-season tires. The Pebble requires no WDH or sway bars, and tracked very well in all conditions thus far. A full description can be found at pebblelife.com.
One unique feature of the Pebble is Tow Assist, whereby the motors engage to offset trailer drag. These motors, remotely controlled via the iPad mini, also provide maneuverability around a camp site, driveway etc.
Tow Assist is seamless, switched on and off from the iPad. The Rivian has so much power that relieving it of trailer drag isn’t immediately perceived as a huge difference. It’s more apparent on steep grades or merging onto the interstate. One can observe the difference in efficiency after a bit, and regeneration to the Pebble pack during downgrades or braking is displayed on the Pebble app. alongside solar input. I noted 6.4kW on some long downgrades.
The Pebble has great aerodynamics, with no aircon units on top, minimal vents and recessed solar panels. The Aero Box on the bow (covering the 15,000 BTU heat pump) raises for towing, presenting a clean entry. The R1T was not as sleek on this trip, with two cargo boxes atop the bed, so some efficiency loss there.
Efficiency varies with a number of factors, short run comparisons are not statistically valid, and I realize that these early results are hardly scientific, but do offer a glimpse at the benefit of Tow Assist. Interstate driving is generally my worst efficiency. I tow at 65 mph. and am buffeted by the bow waves of passing semis.
My ‘baseline’ efficiency for comparison was an average 1.1 mi/kWh for our 7500 lb Airstream 28, over 14,000 miles.
The Rivian recalculates trailer weight after every hitch-up and a few miles of towing, rounding to nearest 500 lbs. One can also force a recalculation from the trailer display. Without Tow Assist the Rivian estimated the weight of trailer at 6500 lbs. With Tow Assist the Rivian in motion recalculated the weight of trailer at 5000 lbs.
With Tow assist, a 168 mile run on I40 at 65mph yielded efficiency of 1.76 mi/kWh.
We left Gallup NM after charging at the RAN to 94%. Having made the run from Holbrook to Gallup without Tow Assist, the navigation system estimated our home arrival SOC at 4%. A bit risky, as there is but one fast charger en route, and that at a GM dealership in Farmington with uncertain availability. I’ve had to stop there with the Airstream, and it’s awkward. We rolled and I activated Tow Assist. I towed at 65 mph, but this time on NM 491 with little traffic. The estimated arrival SOC increased to 26%. No charging stop required! We arrived home after 156 miles and 1200 ft of elevation gain with exactly that 26% SOC, in a brisk 30F.
We look forward to many great trips next year, but now it’s snowing and time for covered winter storage.
Pebble battery management involves a learning curve. The electric appliances, particularly the HVAC in freezing weather, consume a lot of energy, as does Tow Assist. Solar charging helps, but low sun angle in winter reduces solar gain. If heading out for dry camping, preserving the battery SOC for domestic use is important. If towing with an EV and making miles toward a campground with electricity, then using Tow Assist may be more efficient.
A few suggestions from our 1100 mile return trip home in Colorado towing our new Pebble with our R1T.
Take your time, ask every question that comes to mind, but don’t sweat not learning it all right away. It’s a trailer, and should follow you home.
Schedule your delivery to escape Fremont before commuter traffic, if there is such a thing. Leaving at 1600 to head to San Jose with a new, expensive trailer on the hitch was terrifying. There was a particular multi-merge that would stress test anyone not hardened to San Francisco traffic.
Plan to spend a day or three nearby to actually browse the owners manual and become familiar with the systems. Sure, we’re very experienced Airstreamers, but this is a very different trailer. We stayed in Coyote Valley Resort, between San Jose and Morgan Hill, which is very nice, peaceful, and close to markets for provisioning.
Don’t stress over storage. In time, you’ll find the optimum containers that will stay on the open shelves and organize the closets. Just stuff it all in for now
Try a night off grid. This is where the Pebble really shines. We did a stopover in Mojave National Preserve, Hole in the Wall Campground.
Be prepared for considerable attention and questions at campgrounds. One fellow suggested that I set up an information booth. The fifth wheel / diesel truck guys may be skeptical. Keep a sense of humor.
Safe travels and grand adventures.
That’s an open issue with me. My Pebble is under cover, and does have a 20A circuit available. The Pebble Service Team advised me to not leave the unit plugged in, but I still have concerns over the SOC. For now, I visit weekly to wake it up and check SOC. I don’t yet have data for self discharge in storage. It received an OTA software upgrade recently, and Melissa was able to remotely verify that all was well. I’ve submitted a request (case assigned) for the ability to remotely check SOC, similar to my Rivian and Polestar.
Melissa? The Pebble team seems pretty lean with everyone serving multiple roles. Re: power… (questions, not statements, since mine is still sitting in the parking lot at Pebble): So the only power IN options are solar and the charging port, right? So that means there is really no way to minimally keep the trailer on ‘life support’ when stored (under cover)? But Pebble doesn’t suggest keeping it plugged? Seems problematic, especially in the cold climate or when stored remote from home. Yeah, remote SOC monitoring seems like a great idea, although would require cell or internet connection. Re: OTA updates, do those get rolled out to the entire fleet at once (similar to my Rivian) or (at least for now) are they more bespoke with individual owners and related to individual issues or owner ‘beta testing’?
Only cruise control, not adaptive cruise control or any other driver assist features which are blocked when any trailer is connected.
I am considering replacing my Tesla Model X — which I have been using to tow a 2200 lb Safari Condo Alto trailer for 9 years — with a Rivian next year. The Model X allows adaptive cruise control while towing and it is disappointing that Rivians are still limited to traditional cruise control while towing.
Very interested in the Pebble Flow though of course that would require a different tow vehicle than my Model X.
I am surprised to learn that the Pebble SOC cannot be checked remotely. I did not realize it does not have its own internet connection.
Thanks very much for your informative posts.
The selection of the right tow vehicle for an electric RV towable is a complicated choice. While the Rivian R1T is a great BEV tow vehicle, it is missing a very important functionality. It does not have a NEMA 14-50 in the bed, just 110 volt connections. That means you give up an extremely important functionality towing or camping with an electric trailer (or any trailer) because you cannot Level 2 charge the trailer from a Rivian. This is very important feature for the big battery electric towable RV's. Essentially a requirement in my opinion.
Actually the Pebble does have its own cellular internet connection that can be used by the manufacturer to monitor telematics. But so far that has not been exposed to owner access.
Thanks for your comments, and you make a good point. However, I have only driven EVs since 2013 and will not consider any ICE or hybrid as a tow vehicle. Towing my Alto trailer with a Tesla has been a relatively easy experience but of course the Flow trailer is in a whole different class in terms of weight (though it is much more aerodynamic).
And towing a Flow with an EV means managing two large batteries instead of just one. While the capability of DC charging a Flow when enroute from one campsite to another may sound like a great idea to some, in reality the size of the Flow means that it is far too long to fit into charging stalls at a Tesla Supercharger or other DC charging network, and few charging stalls are designed as pull-throughs. If the charging site has a lot of stalls and isn’t busy then you might be able to position the Flow to charge while blocking multiple stalls.
If one arrives at a campground with both the Flow and the EV tow vehicle batteries depleted, it’s going to take a very long time to charge them both even on NEMA14-50 site power.
For those reasons I see the Flow electric drivetrain as an occasional adjunct to extend towing range, not something to be used routinely. Careful planning would be required. But after 8 years towing my Alto with an EV I’m used to that.
Given current technology, that constraint gives you no options for a large battery EV tailer. It sounds like you understand the constraints of towing a large battery EV trailer with a BEV tow vehicle. You can enjoy the ride but at some point the bill comes due for more watts. And with two big batteries that bill will cost you in time and inconvenience, far exceeding 10 minutes at a gas station where you get 100% of your maximum range. Towing a large battery EV trailer with a BEV tow vehicle, over a long distance, will easily add 30% or more to your door to door travel time. Adding watts to two big batteries in a 50' rig is not an easy job.
Towing anything with an EV adds time to the journey compared to towing with an ICE, because as you noted, charging takes significantly longer than pumping a tank of gas. But I don’t mind the extra time spent, it gives me the opportunity to have a break and walk around. My wife and I don’t like to sit in a car for more than two hours at a time, we want to move around. It takes us about two minutes to unhitch to charge the car and three minutes to hitch up again. We’ve been doing it for eight years now and we never tow over 102kph/60mph.
I don’t see any significant obstacles to towing a Flow with a Rivian.
Hi all - awesome thread on your first tow journey. just about make a reservation on a Founders Edition. Are you happy with your Pebble Flow so far? What are some insider tips to look out for? I am an RV newbie. Thank you in advance for your expert guidance.
