Recessed Clearance lights
GWW
I have a 1988 Holiday Rambler Crown Imperial 5th Wheel. The clearance light lens are broken. 5 yelliw in front. 5 red in back. Dimensions are 6" x 2 1/4". I do not want to attach lights on top of these. I want the original RECESSED design. Any suggestions where I can purchase some? Perhaps a 3 D printing wizard or a store that sells red and amber plastic that I could cut out. The last option might be the most probable. Thanks in advance.
Don't know what part of the country you're in but here in phoenix we have a place called State Trailer and they carry dozens of different lenses, not sure if they have those.
You can look online.
I had the numbers on ours for a 2014 Forester. Unfortunately they were not made any longer.
I found some on eBay to replace a missing one and had a couple spares then.
If you can find the lense number I’d try searching that way.
Thank you. I will check them out.
Try EBay. I needed a valve cover for 2018 Equinox. GM no longer makes them, found one on EBay.
