Question Recommendation for Stabilizers/levelers for 2021 Coachmen Leprechaun 26DS with 2 slides
mbaugh55
Good morning,
Just purchased a 2021 Coachmen Leprechaun 26DS with 2 slides on the drivers side. It leans even on level surface. Any recommendations for stabilizers?
I previously used my yellow blocks to level while on a gravel surface, thought a concrete pad would not need them, but the slides make the unit lean.
I'm concerned that it leans this much and the ramifications long term if stabilizers are not added.
Thanks in advance,
MM
Do not put the taller braces under the slide outs, not recommended by the people that make them. Whatever you use, do not lift the tires off the ground with any jacks or stabilizers. A class C frame should be rigid enough to put scissor style jacks under each corner on the sagging side.
