Recommendations of SUVs to tow 3300lb travel trailer
OlesOdyssey
Erie, CO
Keystone
Bullet Crossfire
Hello all. We recently purchased a 2021 Keystone Bullet Crossfire ( 3300 lbs dry weight) and need an SUV that can tow the TT comfortably in the Rocky Mountains. Thanks in advance for your recommendations!
3300 lbs is very light compared to most travel trailers. So just about any full size SUV's with a V8 engine could handle the job. (for instance almost all half ton pickup trucks tow at least 7500 lbs or more with a V8 engine) If you want a crossover SUV with a V6 engine you better look at the towing information in the owners manual to see what it says. Also, just as important may be the towing option. Without it you will have to install a tow hitch, wiring for towing, trailer brake control, and maybe helper springs in the rear. A vehicle with the towing option from the factory saves a lot of headaches.
Hope this helps!
