Refrigerator Problem
rjshiflet49
RVF VIP
Parker County, Texas
Cruiser Aire
2022 Ford SuperDuty
Our Everchill (or as some call it "NEVERchill") refrigerator has a real problem. Last year during our month-long stay on the Texas coast, it iced over, and even after a partial defrost it never cooled in the refrigerator portion appropriately.
This year I bought a battery-operated fan cube to circulate the air, and it helped, but minimally. The freezer stayed plenty cold - except for items stored in the door- but the refrigerator would warm to 50+ degrees. Again, a huge block of ice formed over the vent openings where cool air is supposed to circulate between the freezer and the fridge.
The refrigerator sits on the back wall, and that's where the evening sun hits, but temperatures were only in the 80s for highs most of the time.
Does anyone have a solution for this?
In our driveway in North Texas, where summer temperatures regularly reach 100+, parked in our driveway (but with the rear of the trailer in the morning sun, not evening) it stays cool all summer long. Humidity difference?
Any suggestions would be appreciated.
There were a few Neverchill models, but IIRC they had a freezer section and a refrigerator section that were coupled behind a back wall plate that was removable.
Behind that plate there are the coils in the freezer section, a thermistor to detect freeze-ups, and a couple different mechanisms to transfer cold air from the freezer to the refrigerator section.
Those mechanisms changed a LOT over a few years. Some of them had trap doors that had to open (and failed), some of them had active fans (that failed), and some of them were passive if the freezer was on the top (that failed).
The failure mode was always the coils and everything behind that plate in the freezer becoming a solid block of ice.
A refrigerator should be a closed system unless the door is open. If there is enough moisture to freeze things up, either the door has been left open for a long time, copious steamy foods have been put in the compartment over time, or the door seals have failed. It's usually the door seals, (or on absorption refrigerators the little porous plug in the tip of the condensate drain tube may have fallen out.)
If you do a dollar-pull test and find that your seals are bad and no longer available there is thankfully a possible solution. Many Norcold refrigerators were thrown away when the door seals failed because the seals are molded into the doors during manufacturing and are NLA. (Now everything on a Norcold is NLA, since they're bankrupt.) But the seals were originally made by cooler-gaskets, at cooler-gaskets.com, and you can measure yours and order them direct. It's worth a call to see if they supplied Neverchill. It's a razor knife and 3M adhesive process to replace them.
I believe Neverchill went out of business also. There is one setting down the street where I park my RV. The owner got fed up and put in a residential. Didn't Lippert buy them?
Lippert's subsidiary Furrion acquired Everchill and Greystone just after COVID. They kept the names for a year then swapped it all to Furrion.
We've checked the seal.
We are very cautious about opening the doors, and when we do we are in-and-out as quickly as possible.
Still temperatures in the freezer stay in the ZERO range, but the block of ice that builds at the back vented area prevents air from circulating (despite the fan) - and temperatures in the lower/refrigerator portion of the unit soon rise into the 50s and 60s.
Thank you all.
I had a customer that had this problem. I told him to clear everything out and defrost it. Give it a fresh start. He was heading out on a trip and needed it to work. He contacted me to tell me it was working and thanked me for saving his trip and he would be in touch if it happened again. He never got back to me so.......
