Replacement headlights for Newmar Ventana
Staff member
RVF Administrator
Full post of the actual install:
Previous post:
I ordered these headlights as someone mentioned them with better projectors and LED lighting over the reflector type in my 2017 Newmar Ventana motorhome. I'm not sure when I'll install them and I have to review the wiring as I think there is one catch to the wiring that needs to be overcome, I'll report back when I know more. The other thing is I paid $225 for the pair, now they're listed as $375 so not sure why the price swing. Add them to your cart and watch them as I've done. If anyone knows good or bad on these please let me know but I'm going to explore them as a replacement. I do have the LED lights in mine as I mentioned somewhere else (I'll get the link to those next) and like them but these may be better in the end.
https://www.amazon.com/gp/product/B0038AVAR6/?tag=rvf01-20
I will be looking to replace my 2020 NADP headlights at some point, as we do travel at night some. Do you just google the number embossed on the headlight to find the automobile equivalent? I know about getting the ones designed for LED’s...
Late to the party...as usual :)
So, I tend to be a daytime driver. My use for headlights has mainly been to give truckers a courtesy flash to let them know they are clear to change lanes. That said...on our journey home from Napannee this winter...we were staying in a Jellystone in Cave City...and in the morning, very early...the weather was coming towards us with a high likelihood of tornado activity. Being the diligent pilot...I decided we should break camp early to avoid entanglement with the weather. The park was a twisting turning mess of roads, and terrain variations...making it difficult to see...and our crappy headlights became a problem. We got out of the park...and once on the highway, it seemed like a non-event. I do think it is time to readdress the headlights. You just don't know when the same type of circumstance will arise...and having a better view of what's around, maneuvering might make a difference in how much body work might be required to fix the damage caused by the obstacle you couldn't quite see.
That said... @Neal... how are your Headlights working? I have done the sanding/ceramic sealer thing before...and it's time to do it again...but am I better off with LED lights in the original housings...or upgrading to the projector type lights that you added? And is halogen or led the way to go.
Always ready to gleen good info from the trailblazers doing the hard work!
I like the headlamp assemblies I replaced the factory units with and then put the Fahren LED's in and they work great. Wasn't long ago I drove it home from storage at night and appreciated the bright white LED light which is common on the roads now.
Thanks... So, Projector and LED for the win. Wonder if anyone has that combo in one product...or if it's a two step process.
No mods, just use blue tape to protect the chrome.
Hmm… off hand is there a particular H_? number and Lumens that are preferred? I’m clueless…and hopefully don’t want to trigger a smokie to ticket me for too intense headlights. Oh wait…I do want to see if there is a Binford 5000 model, oooh, oooh, oooh!!!
Looks like from my Binford order history it's H13/9008.
You'll want the brightest you can find but be forewarned, the marketing of these LED bulbs can be suspect. I've seen some where they sum up the two bulbs to get a total lumens which is not correct. Just do your research and find what you like, they're not hard to swap out. Of late I really like the Fahren brand and have them in the toad as well.
I guess I need to get more schooling...
When I looked at the Headlight assembly link...and went to their website. They mention H1 and H7. When I look at the bulb website...they mention H13 are for fog lamps?
Did you replace both bulbs with H13? or one?
I replaced both high and low beams with the LED set. The headlamp assembly may or may not come with bulbs, I don't remember and you may have a good point, the bulbs that were in the prior headlamp may not be correct for the replacement headlamp and I need to check into that. Good catch. While what I have in there works, it was a struggle to put in one side.
I looked up Sylvania bulb configuration for an OEM Dodge Nitro...the reflector type we had stock is an H13 in both High and Low beam positions.
I put the same in high and low beams
Yes my ‘16 Ventana had H13’s but the Sylvania bulbs were crap. Went to M4 products and got their H13 LED kit and was thoroughly satisfied.
So...probably 3/4 of my issue was lens oxidation and yellowing. So, I tried one of those refurbishment kits that make acetone vapor. Way better lens clarity...and if the headlights aren't ON...they look great. With headlights ON there are stress micro cracks that appear...so, eventually --- I'll buy new housings.
Then I added H13 LED replacement bulbs. The difference is amazing. I cannot believe I went 9 years without doing this.
photos:
1) Original fogged housing.
2) Refurbished housing.
3) Refurbished w/original Halogen.
4) Refurbished w/ LED replacement bulb.
The last two photos don't do it justice...my camera was above the light pattern. If I squat down to the beam pattern...WOW!! Good to know I won't blind anyone...except go-cart drivers.
