replacing tires
pushnrv
I have a 2019 Tiffin Phaeton 37 BH. With original Michelin tires I need to replace.
Any suggestions or stay with the Michelin?
I am in the same position. I price out a set of six 235 80 R22.5 XRV at a cost of $5,500 Cdn Installed, Balance with a Wheel alignment. I have not checked another source yet as I just started this morning. I was expecting about a thousand dollars less. Thoughts?
That's just under $4k US which is not bad. I paid just over $4k US for six 19.5" XRV's, no alignment, 2 years back.
I replaced my Michelins 22.5 with Toyo M154, less expensive and over a year and I'm completely satisfied. I got then at motorhometires.com.
I had Toyo tires on our Georgetown that we previously owned. They performed very well for us.
What size do you have or nee? There are many tire options out there tha are very good. Toyo prefeered by many. I will probably be going with the M144. I use the 295/80-225.
Depending on your rim size, (width) you may be able to go to a 255/70-22.5. A bit more common size. Same diameter, just wider and resulting increased capacity.
For years and years I heard that Toyo is a great replacement for Michelin tires. I have never run anything but Michelin on my four different A class motor homes.
But Toyo is always highly recommended.
HH
We had Michelins but switched to Toyo a little over a year ago.
Like them so far, no issues.
Running 8 of the M647 on the rear and 2 steers are M144.
