Resizing Images when inserting into your message
Administrator
Cummins 400 HP
I learned something today when creating a post just now. When you attach an image you can insert a thumbnail or full size image into your message as you wish. I often prefer the full size image but it can be quite large at times. If you click the image there is a toolbar at the bottom that will appear that allows you to add a link should someone click the image or change alignment or sizing. However, a better way to change the size is click the image and you will see small squares at the corners called grab handles. Just click and drag one of these to make the image smaller or larger and it will size the image in both height and width proportionally. Very cool!!!
