Rid X
sheridany
Orinda, CA
Prevost
Marathon #1361
Prevost
Volvo D13
2023 Jeep Grand Cherokee
I want to clean my black tank and I have had a few people tell me to use Rid X mixed in with water full to the top. Let it sit for a week or more and then dump and rinse a few time. Anyone tried Rid X?
I use cascade liquid. Seems to have worked best for me.
Unless you have done something to cause a severe solid build up, I would think that the Calgon or dawn heavy mix with a full tank sitting for 24-48hr would solve the situation. I do this a PM in the black and gray tanks once a year, and then use them without ever doing backwash or other treatments year round.
I keep the gray closed when in use and drain at 80% routinely. Same with black tank, but I suspect everyone treats black that way.
The most harm I have seen is to gray tanks that are left open routinely. Grease and food scum build on walls and smell.
How much Dawn do you use?
I probably use too much, but I have those small dollar general sizes and use the whole thing
Since I started using Cascade Liquid DishWASHER detergent I haven't had any issues with my level sensors. I use about ¾ cups in each tank when they are at least 50% full. Drive for a day and you will be amazed at the black gunk that comes out which I assume is mold.
The problem I had when using Dawn is that it suds so badly that it's hard to get all the suds out, which interferes with the sensors.
Rid X is used in septic systems and unless you fill your tanks and let them set for several weeks, it will not do much good. It takes bacteria weeks or maybe months to have any effect. Maybe add a little tofu!;);)
I use Cascade Platinum Plus pods in my home dishwasher.
Wondering if throwing 1 pod in the head several days before dumping would be of help occasionally.
If it's not a macerator toilet it should be fine. If it were me I'd throw 3-4 in and then fill it with water, let it soak overnight then dump and you should be fine. I don't typically use the cascade in a black tank unless it has only water.
We use 1 cup of Pinesol. We used to use Dawn but had too much of a sudsing problem. If the water is hard, I will add a couple of scoops of Borax to soften things up. Both black and grey read accurate in our 14 year old coach.
Darrell
We use AquaMax in our tanks.
While at Newmar the last time we were still having issues with the black tank levels (pressure sensor type).
They had replaced so many under warranty they decided to do some testing on an old cruddy tank.
Cut the tank apart and tested various types of cleaners. Aqua Max ended up being the one that worked.
Since that trip we have only used that treatment and, when I recalibrated the black tank levels after treating for a while, they have been accurate ever since.
So long story short, it has been about 7 months and the black tank continues to read reliably.
I also use the black tank flush until clear each time I dump the tank.
I think whatever is used, the agitation when driving, helps immensely. I sit for six months. After three months, only driving with Dawn or Aquamax seems to work.
