Roof AC question
You might be able to tell from your thermostat. Look through the settings for each A/C. There should be a HP selection on the ones that have that option.
Thank you. I did not go through the whole story, just thought someone would know off hand.
I am looking at buying this RV used. So I can get this RV under my house I am having them install a low profile AC . They said the rear AC (The only one that needs to be changed) does not have a heat pump, just the front one! .
Generally, heat pump in the rear was an option.
I have a 2011 34TGA and do not have a heat pump on my rear AC. AC / Heat Pump combo on the front unit only.
