Rooftop AC cycling
Stopher50
Like the title states. Compressor kicks on for about 20 seconds then kicks off for a minute then restarts over and over. Voltage is good to the trailer and replaced the capacitor. After about 5 or 6 cycles it stays on. Seems to be getting worse as time goes on. It’s a domestic unit not sure which one
Did you check for loose wiring?
Did you reset the thermostat?
It almost sounds like a weak contactor dropping out. Have you checked the roof top and cleaned the fins to ensure good airflow?
Thermostat or control box. Control box has a relay that powers the compressor. Thermostat tells the relay to close so it can cause this. What thermostat is in the system?
