Rubber Roof recoating
easterdr48
Keystone
Outback
Tow
I got on 2010 travel trailer TDPM rubber rv roof and needs to have new sealant rolled over it. What is best product to use in 5 gallon bucket.. So many products to choose from I plan on doing the work myself. Need another 10 yrs of RVing with my unit. Thanks for any recommendations.
Don't think you can do any better than Henry's tropi-coat 100% silicone roof coat. The product according to their website is formulated with RV rubber roofs in mind. You won't be unhappy with the warranty either.
I seen this product online. Thanks for replying to me.
I will attest to the quality! Have used it on 3 roofs, and painted a plywood slide in camper that went through a tornado and was totally dry when I was able to inspect it. They use humidity as it's catalyst, so won't effect your roof.
Here’s what I used. Helps with the heat too.
Thanks
I thinking about doing the roof in June in southeastern VA. Humidity shouldn't be an problem. Thanks for reply. How often need to repeat process on rv roof?
It’s been on for 2 1/2 years now. No issues. Just keep it cleaned.
Henry 100% silicone will likely outlast your RV.
I was going to get started on next week but so much rain in forecast. I thinking about waiting until late Sept/Oct to applied Henry Tropical Cool Silicone 100% coating onto RV TPDM roof. What should I use around vents chalking Henry Prep 884 or Dicor Lap sealant? I just clean roof next week with Dawn detergent/ hot water mixed. Thanks for advice.
I use Henry's roof seal, yes tropi-coat.
I did the same as Kevin.
I finished up with re-coating my 2010 Keystone Outback travel trailer roof with HENRY TROPICAL-COOL 100% SILICONE rubber coating and was amazed at finish job. Roof stays so much cooler and white. I would recommend this product to use and add years to life of TPDM roof.
