Answered Running power from Bay 1 on Driver side to Dash
GUS2000
South Louisiana
Dutch Star 4369
2017 Ford Explorer/2018 Ford SuperDuty
Has anyone run power from Bay 1 on the driver side (where all the chassis fuses are located) to the dash?? wondering how hard it is to fish a wire from that area into the dash area..
Its simple. At the top of the bay is an opening that feeds up into the interior side panel on the left side of the driver. Simply remove the top trim where the gear selector is mounted then you will see a whole mess of wires that feed down into that bay through the opening. Just feed a wire up through the bay and look for it in that mess of wiring.
X2…very simple. Many of us have done this to operate the driver window
awesome! thanks guys!!!
See if this helps:
this is perfect.. only access i will have is via the leveling system since our shifter is on the steering column... but this really helps!! thanks!
