The fact that it has more lead in it does that make the battery better or just heavier?You probably don't have a lot of choices since you’ll likely need to stay with the same dimensions and you most likely don't have a lot of extra room to work with. So unless you want to get into a project and most expense and go with lithium, the decision will come down to AGM or standard lead acid.
Looking at specs, make sure it will fit of course, and then look at he weight. The heavier the battery, the more lead in it. Look at specs from cheap/chineese batteries and you’ll see they are several pounds lighter than the more expensive US made examples.
If you want the batteries to last longer AND you are going to monitor and maintain them well, get the best you can. Trojan was the best in the business for years, but they have some competition these days. Just look at their specs and then shop around.
