Shore Power won't work inside motorhome
jpotter
We are new to this 2019 Nexus RV Ghost. Had it plugged in at home and everything worked on Shore Power get to the park and nothing works on shore power at park. Checked the breaker at Pedestal, verified cord connection that's ok. Verified power coming into the coach but nothing works. What are we missing or doing wrong?
TIA
Welcome to RVforums from Ely, Iowa. Check out the breakers to see if tripped. Also check to see if any breakers on the inverter/ converter have tripped. The other item is to check and see if the transfer switch is operating.
Good Luck! keep us all posted on what you discover as other will experience similar issues.
