Skylight Leak
Jerryrapp
2023 Grand Design 2970RL - anyone had leaks coming out of the underbelly cover or in their shower? After searching for a while I found the bathroom skylight had several cracks and that the protective caulking was not applied correctly. Leaks were showing up inside the shower and through the underbelly in locations depending on the level of the camper. This is a warranty issue and have registered with GD. I would suggest you check your skylights and vents. Ours were not caulked properly. This could be damaging the interior ceiling, walls and flooring.
Ouch! Thanks for sharing. I'll check mine soon.
