Slide controller location
Springhook
2021 Freelander KB29. Looking for the location of the rear slide controller. I found the front slide controller on the storage compartment ceiling under the front slide. Also, where do the slides get their 12 volts. Power panel fuses not marked for slides. Thanks.
The controller for the rear slide is likely in the area of the slide. All of ours are mounted in the storage bay closest to the slide.
You likely have a controller somewhere that the power goes through and sends to the slide. What type slides and control panel do you have. Do you have the intelitech control panel?
