Slide out Lock arm
JBright11
RVF VIP
South Central Kansas
Bay Star 3629
37'
F53
Godzilla
on the hunt for a toad
Took a quick run last night to fill up with fuel for our upcoming trip and noticed that the slide lock arms on my dinette slide were making more racket than normal.
Took a look while the tank was filling and found this silver nut had backed off a bit. I just finger tightened it back up against the stop nut and it seemed to quiet down. My question is what does this nut actually do and how do I verify that it is back in the correct position? I have no clue if the threaded rod had backed out from the stop nut. I've sent this to Newmar's baystar email but thought I'd ask here as well.
Don’t know. Mine did the same. Tightened it wirt crescent wrench ans has been fine ever since.
Appears to be a jam nut that should be tightened against the large nut as AbdRahim mentioned.
The nut is a jam nut holding in what is sometimes called a "bullet point". Imagine a set screw that has the center drilled out and a spring loaded ball is inserted. Then, the edge of the hole is bent in a bit to hold in the ball. Now, the ball is protruding from the end of the screw and is spring-loaded. The idea is to apply that bit of spring tension on the ball and then onto the lock arms. When the lock arms are retracted they reduce the rattling. When the slides are extended, they tend to hold the arm in the straight position. The adjustment of how far they protrude onto the arm is very finicky.
OOPS!
For some reason, I did not see the photo in the original post. Never mind the above explanation, but I'll leave it for reference.
