Slide room alignment issue
pheidbrink
2022 Winnebago view 24D. Slide room fails to fully close by about 1 inch on the front edge only. Makes a loud “clunking “ noise at the end of the extension and retraction every time but “normal “ sounds during movement. Expect that there is an alignment issue with the front tracks and gears. Any one experience this issue and can suggest a fix?
Some slide mechanisms have a nut that can be adjusted to change how far the slide closes but it's not something they recommend that you do by yourself. Take it to a good RV shop and have them take a look.
Thru frame, Schwintek, Slimrack, electric or hydraulic, etc.
