Smoking while ascending a mountain
JerryR
Our 2001 Fleetwood Flair had periods of white smoke coming from the rear as we were ascending a mountain. Does anyone know what might cause this?
White smoke is typically coolant. Oil burns blue, excessive fuel makes black smoke. How many miles on it? Also are you viewing this as the driver in the mirrors/back up cam, or was this reported by someone following you?
Just a wild guess, but is this on a GM chassis? Also how many miles on it?
It has 99,000. It was seen by my wife who was following in our toad.
Gas? Diesel? Rich is right, white smoke is typically coolant. If it's a gas engine you may have a head gasket beginning to fail. If it's a diesel engine you may have a problem with a cylinder sleeve being pitted causing it to leak coolant into the combustion chamber. Is your coolant low? Anything in the overflow tank?
its either an F53 or Workhorse 7.4, and my guess is its not an F53.
