Kevin D Pem
RVF 5K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
I should have been more positive! Sorry!Maybe this should be “soft floor #2”.
If / when I find moisture what’s a best guess cost to redo the whole floor correctly? 37 ft 5th wheel.
Not overly handy. Maybe I should ask cost to have floor redone?
My rig was considered a lite in it's day! The underside is the same aluminum siding,as on the sides. That is glued to 2" of foam. Then is 1/2 marine ply. It is not built like a house,but still somewhat of a rock. However at the seams where the plywood meet all flooring would crack.
When it came time to deal with the floor. Those cracks were my only concern. That's My extent of OCD! however I hatched a plan that took maybe two days to fix the issue.
So, because some of you'all have soft floors your dealing with,once again I'll show case my fix,that should help you out!!! My fix also became My finished floor cover. The cost was less than standard flooring, will less problems over time so grab your popcorn and dream of better days.
Excuse the dirt, I only moved this morning so haven't been on My knees with spong yet.
What you see is 1/4 underlayment.
It was ripped into 3" strips. Glued to the plywood and pin nailed to keep it in place while the tight bond 3 dryed.
I followed the finish as though I was installing cork. In the four years it has been there I have sanded and re varnished once.
Of course this is what I did! You can put any kind of flooring over it.
What it did was remove any trace of a seam. Added 1/4 inch to the plywood that was there. And made any flex a thing of the past..
Just a note: it worked so well that when I added hydronic heating, I raised the floor for the heater tubes in the living room with the same method, only using the same 1/4 underlayment as the subfloor with many ripped 1x 3/4 strips between the tubes.
So yes you can re inforce the floor without a major rebuild.
