Solar Panel Manufacturer?
IronAngel
So, I have a 2026 IBEX 25MLB with Beast Mode package and there's 400 watts of solar on the roof. It's my understanding that the 2000 watt inverter can handle up to 2000 of PV watt input. I do not intend to install that much btw.
Without removing a panel to check, does anyone know who makes the factory solar panels as I'm looking for specs please?
Thanks from a new FR IBEX owner.
What you need to know is panel voltage (measure at solar controller panel port.), and the controller specs.
If the specs are part of the inverter,as you stated,what you have is referred to as a solar generator. In that case the specs are in the solar generator information.
The panels voltage should be the same. You already have the their wattage.
lol, so 200 watts divided by 12vdc = 16.66 volts and as they are installed in series, 16.66 x2 in series = 33.33 volts. I knew this just wasn't thinking of it. now to find 300 watt solar panels with 33 max volts and I can install them in series/parallel, ok. Thanks for your reply. I'm a newb to solar but understand watts and PIE rules...
