Problem Splendide E1 F1 Error Code
GUS2000
South Louisiana
Dutch Star 4369
Freightliner
2017 Ford Explorer/2018 Ford SuperDuty
Has anyone ever had an issue with the Splendide washer where it gives you an E1 F1 error code?? if I turn off the breaker and wait a few minutes, it will be fine for a few loads and then error out again...
any insight would be great!!
From what I can find it is a problem with the main control board.
We worked with Splendide on a bad door lock and they sent a whole wiring harness, control board, and new door lock switch - just in case.
Thanks guys! I emailed Newmar Service and will maybe reach out to Splendide directly also.. wouldn't be bad to have a spare board!
Yeah, when we had the door lock issue on the washer they got Splendide on the line so we could all talk through the issue.
Did like that they sent additional parts I didn’t need at the time. Do need to get another door lock switch just in case 😊
E1 F1 error code means your main control board has a short and needs to be replaced to resolve the issue.
