Starlink risk of Bricking
JoeHogan
Florida
Dutch Star 4311
Spartan
Cummins
2018 Ford Flex
Thanks, I am coachless for 4 months so I unpacked the SL and am updating as I type
For the most part, I don't think this is a problem at this point. I may be mistaken, but if not, then:
  • If you have one in "standby" mode, it will/should update itself.
  • If you have one that is "paused" then it probably would have stopped working when the deadline to put them in "standby" mode expired. And if you put it in standby mode, it should have updated by itself.
  • The only thing to watch out for is if you have one (or more) that haven't been activated yet. When you pull it out of the box and fire it up, it will update the firmware and when that completes, it will activate itself and you will start being billed. At least, that is what happened to me.
A call to support, and I'm using the term "support" with a great degree of generosity, is usually the last thing you want to do, right after yanking all your teeth out with a pair of pliers. I dredged the thought, but it appears that Elon has finally turned on some AI to handle the support that he was failing to provide in the past. And the bot did a great job of refunding the two months of service that I didn't realize I was paying for.
So watch you don't get caught with the "auto activation" thing!
Agreed, Stand by mode has the bandwidth to update if it is powered and access to satellites. The concern is those units that are unplugged and stuffed in a closet.
Or turned off and parked in a metal roofed garage like mine. I try to pull the unit it out once a month and power up the and reboot to get the latest updates. A bit of a PIA but don't want an issue with the roof mounted Starlink.
So I did the update and will put it out once a month until I pick up the new coach. I forgot what a PITA it is when first plugging in and setting up. Took a while to get a stable signal to keep it connected.
When I get the coach I will probably mount it to the roof.
As a side note, I contacted Elkhart Sat and they wanted more then newmar to install the performance dish. I will install my gen 3 on the roof myself.
I pull the unit from the RV at home and set it up in the yard for service at the house, dumped my cable service.
This might help someone; my camper is under a carport when at home. I unmount the Starlink MIni and power it up with a modest Anker power bank and a short cord. I just put it in the yard any sort of way with some view of the sky, and it talks to to the mothership for updates. I use the portable setup for other activities so it works well for me.
Updated my Mini yesterday. Haven't used it much but what a cool little device. Plug it in and it works. Update started immediately. In the Starlink app click the option to install. Done.
Now need to get the Gen3 in the coach updated. Haven't used it yet other than activation.
