Suburban furnace does nothing
I will tomorrow. no power coming out of where the fuse should be at
Did you ever get it going? If you want to check the thermostat you can bypass it by removing the two blue wires and twisting them together. That's all the thermostat does, makes a connection between those two wires. That tells the heater to turn on. This video is of an old Suburban heater repair, but probably the same principle as the new ones:
Have not yet. I even replaced the thermostat. at first the ac would run on either ac or furnace, now it won't run on ac. so I think im going to return it.
will try to twist the wires together tomorrow. if it don't work, going to try to find someone to take a look at it.
