Question Suspension Upgrade Options
Phillip012863
Hi-I have a 2019 Fleetwood Pace Arrow 33D. It has an XC-S Rear Engine Chassis. I am looking for advice for suspension/handling upgrades. I usually tow with it if that helps. I put Sumu Springs on my prior RV which helped a lot but because this rig has air suspension, I don't think those are an option. I am open to steering stabilizer, antisway bars, shocks, etc. Appreciate any advice...Thank You
Best advice I could give is contact SuperSteer. They are experts in this. SuperSteer
What are you trying to fix ie., are you having issues with sway and steering? Have you gotten a Cat Scale weight and adjusted the front and rear psi in accordance with the tire manufacturer's load inflation table? Over inflated front tires, especially, will produce squirrely steering.
