Thermostat
Russellvh
Forest River
Wildcat Fifth-wheel
2019 Ford F-250.
Yes
Another newbie question.
Wildcat 5th wheel 2022 #333RLSB
I have 2 thermostats. One in main / galley area and 1 in the bedroom. Does that mean I have 2 heaters? Only noticed 1 outside vent. If not, which thermostat takes priority when setting.
Do they both have a heat setting? What does your owners manual say? Off the top of my head I would guess the stat in the main living area is the primary if you only have one heater.
You're close, it most likely means you have 2 Air Conditioners.
Usually the heating is controlled by the "galley thermostat" for the entire RV.
There is a chance the 2 A/C's have heat pumps (check and see) if they do you can use them down to about 40 degrees. My guess is you don't have heat pumps.
We have used space heaters for years to supplement the RV heater.
Great help. Thanks.
