retirement2025
- Jan 4, 2026
While on my retirement trip last summer traveling from Florida to Colorado I encountered an issue with the coach. I was pulling a dual axle cargo trailer with a weight of 5000 lbs. The coach weight and the Cargo trailer weight combined was around 17000 lbs. The issue which occurred on multiple occasions was the coach would without warning shutdown indicating a fuel issue of some sort. Replaced the fuel module several times. Several costly visits to ford who gave us no help at all and could not find the problem.
They did provide the following explanation after replacing the fuel pump, Fuel Filter & PC Module." The PC Module they felt was receiving an overheating code telling the PCM to shut down in which the PCM sent aa signal to the fuel module to shut down. There were multiple times on the interstate systems the unit would shut down in traffic, and I would pray that I could get to the shoulder without causing an accident. I can attest to the fact that it was not overheating. In fact, the other day back in Florida temp.45 degrees left my home made it 6 miles from the house, same issue, I disconnected the trailer brakes thinking that maybe an issue with the plug. I made it another 6 miles, same issue it shut down. I then disconnected the cargo trailer from the coach and drove the unit back to the house with no issue. This whole issue ruined my vacation last year and no one seems to be able to help me. The coach has a gasoline ford 350 V10 motor. Please help.
