Tire pressure
Uncle Tuff
Carlsbad, California
Four Winds
Majestic
Ford
Ford Triton E450
Hi, I am wondering what the tire pressure should be on my tires for a 29 foot and Four winds Majestic RV. I have dually tires in the back. I read somewhere that the back tire should be around 80 PSI. However I wasn’t sure if that was correct?
To do it properly, you need to weigh your RV. Get front axle weights and rear axle weights. Then look up the tire pressure in the Michelin tire pressure chart. Every RV will be different depending on how it's loaded. You should weigh it with all the junk you will be taking with you as well as water, fuel, propane, etc. Most truck stops have scales and will be happy to weigh your RV.
